help me, codes, misfire and evap
Old 07-25-2008, 12:00 PM
phatskier20's Avatar
phatskier20 is an unknown quantity at this point
Default help me, codes, misfire and evap
98 bazer 4.3 of coarse 4x4 when you first start the car it skips really bad but clears up for the most part after heating up. there is a small leak in intake manifold gasket. I am getting three codes p0300, p0452, p0453 any hep you can provide will be greatly appreciated. I just replaced the injectors thinking that would cure the misfire code.
Old 07-25-2008, 12:06 PM
WolfPack's Avatar
Default RE: help me, codes, misfire and evap
When was the last time you replaced spark plugs, plug wires, distributor cap and rotor? A random misfire (P0300) is alot of times cured by a simple tune up. Then again, alot of times it is much more serious than that...but always start small
Old 07-25-2008, 01:46 PM
im afraid this is the big one when I upgraded to new spider i replaced wires plugs and rotor just incase even though they all looked good
Kilo
07-27-2013 06:57 AM
Aanenson
11-08-2011 02:50 PM
mikeesho1
10-26-2007 12:31 AM
LittleT
10-23-2007 01:02 PM
drperry
07-04-2007 04:25 AM
Quick Reply: help me, codes, misfire and evap
