HELP Stripped Bolt
Old 04-13-2010, 06:50 PM
moe_23's Avatar
moe_23 is an unknown quantity at this point
Default HELP Stripped Bolt
I'm in need of some assistance with a stripped bolt. I'm in the process of replacing my spider injectors and nut kit. My dumb *** decided to use a allen wrench to remove the nut kit bolt on the back of the manifold and in the process stripped the torque head. Does anyone know what can be done to get it off. I've thought of grinding down the edges and using a vice grip or open end wrench but the are is very tight due to the fuel lines. Any help is appreciated.
Thank you all in advance.
Old 04-13-2010, 10:58 PM
84BlazerS10's Avatar
If you have the right tools I would use a torx ratchet bit set and hammer the socket into the bolt.
c0a8l0v6i8n9
10-11-2017 12:48 PM
nitro7
05-16-2012 09:40 AM
softail88
09-15-2011 06:55 PM
pmezo
04-18-2010 05:13 PM
ComputerNerdBD
14
11-27-2009 06:08 PM
Quick Reply: HELP Stripped Bolt
