Horn help needed
Old 01-11-2009, 04:04 PM
bcobra's Avatar
bcobra is an unknown quantity at this point
Default Horn help needed
My 98's horn has not worked since I bought this truck so I decided to fix it. I cannot locate the horns on the truck at all. I replaced the engine when I bought this thing and I didn't see them in passing during that either. Where are they supposed to be? When I hit the horn on the wheel I can hear a click from the outside fuch block so it sounds as if the wheel is working. No horn is becoming frustrating
Old 01-11-2009, 07:10 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Default RE: Horn help needed
They're both inside the fender wells. One's next to the battery, and easy to get to. The other one's beside the windshield washer fluid tank. You have to remove the air filter box, and the washer fluid tank, to get to it. It's easy, though.
Old 01-11-2009, 07:35 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
I cant recall if pressing one button does one note or if it does both, but you will definitly want to check the power at the horn probably the one on the driver side since it is easier to access. It seems rather unlikely that both horns would go bad unless the previous owner only used the horns instead of blinkers.
Old 01-11-2009, 09:13 PM
NVANZEE's Avatar
it is comon for horns to go bad if they are never used. If they are never used all the internals rust together. If they're used frequently it keeps everything moving.
Old 01-12-2009, 02:23 AM
Blazin1's Avatar
Blazin1 is an unknown quantity at this point
Wow I just learned something new. I had no idea Blazers have 2 horns. I'm guessing my Blazer was missing both because you could only hear a clicking sound @ the steering wheel. I replacedthe passenger side hornwith oneI found at the junkyard and it works great. I will have to check for the second one.
Old 01-12-2009, 04:14 PM
portcqb's Avatar
Yah there is a low note and a high note im not sure which is which im sure you could tell by part number.
Old 01-13-2009, 08:37 AM
Blazin1's Avatar
I'll have to look for 1 next time I got to the Junkyard.
DoinWork
08-22-2013 02:42 AM
chris015
09-10-2012 06:43 PM
carcrazed484
06-30-2011 12:20 PM
972disciple
08-04-2009 03:48 PM
lacewood
07-14-2009 08:49 AM
Quick Reply: Horn help needed
