2nd Gen S-series (1995-2005) Tech Discuss 2nd generation s-series (1995-2005) general tech topics here.
How bad is p0302?
Old 03-19-2019, 04:01 PM
Default Update, problem fixed
So I will update, so if anyone does a search, could maybe shed some light.
symptoms were a really rough idle, no ***** when given gas. CEL was wiped by previous owner, so I could not say for sure if anymore codes came with this code.
I started with the spark plugs, this did not fix the problem, but they were really worn so it did run better afterwards.
next step was distributor cap and rotor. I did not replace the whole distributor, as it would start without an issue. Again the cap and rotor where really worn, so this too helped run better but does not fix the problem.
With a pressure test done, it showed that my injector 5 and 6 where both clogged. Replaced with a "new to me" spider injector, and PROBLEM SOLVED.
I'm sure if the pressure test was the first to be done, I could have saved the money on plugs and distributor parts, but as I plan on keeping the vehicle, it made more sense to swap them out.
Empire932
03-20-2019 11:28 AM
ezblazer
05-19-2013 07:42 PM
betron02
10-26-2010 10:31 AM
Queenpin
03-05-2010 03:56 PM
MRDCSE
02-18-2007 11:51 AM
Quick Reply: How bad is p0302?
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
