How I fixed my P0410 problem..
Old 06-18-2012, 06:32 AM
coolasice's Avatar
coolasice will become famous soon enough
Default How I fixed my P0410 problem..
With Inspection coming due next month I decided to dig into my P0410 secondary air injection problem. Removed the air pump, took it apart, tested, all good, vacuum diaphragm tested and cleaned, all good, vacuum solenoid checked, all good.... fuses, good... check valves good... getting a little ticked off...start looking for broken wires... nothing... just happened to be putting the battery back in and noticed a connector disconnected next to the pcm... plug it in everything works perfectly.... dangit... had this problem since we swapped the engine, must have disconnected it then and never reconnected.... total cost $0 and 3hrs of labor.....
Old 08-05-2012, 06:11 PM
Mtucc's Avatar
Mtucc is on a distinguished road
Sorry hit the button too soon. I had same problem but the previous owner connected the coolant reservoir overflow tube to the air pump intake. What a dipstick but thanks for the info
AKYooper
12-27-2013 01:51 PM
ZR 2
08-22-2008 08:27 AM
steveinmd
01-09-2008 10:03 PM
BlazinJay84
12-13-2007 09:38 PM
flyinbrad
Engine & Internal
01-08-2007 11:40 AM
Quick Reply: How I fixed my P0410 problem..
