How to remove front driveshaft
Old 12-12-2005, 06:58 PM
trudynosports's Avatar
trudynosports is an unknown quantity at this point
Default How to remove front driveshaft
Anything special about removing the front drive shaft? I've got it loose from the front, but it won't come off the transfer case. I need to pull it off so I can change the transfer case encoder motor. Help please, cause I can't find any other info on this. Thanks,
Aaron.
Old 12-13-2005, 03:05 PM
Hanr3's Avatar
Default RE: How to remove front driveshaft
Should be u-joint straps at both ends. Unbolt them and it should come out. You might have to use a prybar, or long screw driver to pry the u-joints out of the fittings. Mark one of the caps so you put it back in the same place, I use white out. Carefull the caps don't fall off. No biggy if you don't lose any of the needle bearings inside it. If a few of the needle bearings fall out, find them, clena them up, put a dab or two of bearing grease in the cap and slide it back on. Make sure it seats fully and that no bearings lay flat acorss the end of the cap. The grease helps hold the bearings in place, and provides much needed lubrication.
Old 12-13-2005, 09:40 PM
thanks, I got it finally, it was stuck on the splines and I had to lightly hammer it off.
insanefirewall
29
09-10-2014 09:43 PM
gitch93
01-23-2013 04:51 PM
mnmetalhead
22
07-26-2011 09:56 AM
JGarr
14
03-06-2007 07:14 PM
Blasir
10-12-2006 11:32 PM
Quick Reply: How to remove front driveshaft
