How to tell if leaf springs are worn-out?
I was told that if the leaf spring appears to be flat (ie no arch) then it is time to replace them.
The spring appears to be even with the ground in front of the axle, but still has an arch in the rear between the axle and rear shackle.
I was also told that the stock factory springs are rated at under 900 lbs. I see that sdtrucksprings.com has replacement springs with a 1400 lbs capacity for $128. Wonder how stiff a ride these would give?
EDIT: '02 4dr 4wd
EDIT: '02 4dr 4wd
usually a flat spring means time to replace or re arch. there was a place down here that did both of mine on my dodge ram for $60. Did that last summer and so far they are good. look for rearch prices before u buy new.
4dr & 4wd
check ride height?...compare left to right measurements or should there be a set distance between the top of the axle tube to the frame?
Made the measurement and well within range; so I guess they are not worn-out....just weak. Does not take much of a load to bring the backend down....couple of 60lbs bags of concret and its 5" lower at the rear bumper; have to watch it or I will hit my head on the glass door.
Perhaps I just need to replace the springs with higher capacity ones....but concerned about the ride quality if I did this...???
kmartin
10-03-2014 09:54 PM
stretch.chad
09-19-2014 04:21 PM
BlackOnBlack
06-24-2008 11:52 PM
