Hvac
Old Mar 17, 2014 | 07:34 PM
Blazer 98's Avatar
Blazer 98 is on a distinguished road
Default Hvac
This past week I have been having issues with the hvac controls, when ever I accelerate or speed up the heat will blow out the 4 vents on the dash. If I change the control to a different location it will change it, I looked in the engine bay and did not see any loose vacuum lines. It is a non- automatic hvac 4x4 98 blazer. Any suggestions would be greatly appreciated.
Old Mar 17, 2014 | 07:57 PM
Your symptom indicates a vacuum leak. If the vacuum lines are OK as you mentioned, the vacuum check valve is not holding vacuum when you accelerate. This link shows where it is: http://i561.photobucket.com/albums/s...acuumlines.jpg Most auto parts stores stock them, cost is ~ $5. If that doesn't repair the problem, there is a vacuum leak The link shows where all the vacuum lines go.
Old Mar 17, 2014 | 09:22 PM
Blazer 98's Avatar
Thanks, I did a lot of searching, but everything seemed to be opposite of what my problem was, I appreciate it.
Old Mar 18, 2014 | 07:37 AM
LannyL81's Avatar
Find the vacuum line under the hood that goes through the firewall; this is for the HVAC control. Remove the hose from the T and cap-off the T. Then go for a drive and see if the problem is gone.
Also the vacuum lines rot-out, especially the ones in the upper left area of the engine bay. Suggest just buying 10 feet of vacuum lines and replacing them all. Also check the check-valve for a leak.
Old Mar 21, 2014 | 01:24 PM
Blazer 98's Avatar
I tried to pull the vac line from there and was not successful. I did not want to break the line, how easy is it to hookup the vacuum line that goes through fire wall back up? I might just replace it if it isn't too hard to do.
Old Mar 21, 2014 | 04:14 PM
The HVAC line, (hard black plastic) goes from the back of the mode switch, through the firewall, and connects to a rubber line next to the ABS unit.
warthogdriver
Jan 12, 2018 01:25 PM
kota04sxt
Dec 10, 2009 09:34 PM
WisdomRacing
Feb 5, 2008 03:27 PM
okanaganblazerguy
Aug 21, 2007 09:45 PM
laserblazer
Feb 4, 2007 05:20 PM
