i have a problem can anyone help?
hey everyone i have a 97 blazer, i just got it friday and i have a few problems, the first on is my fuel gauge does not work has anyone had this problem and can maybe help wit try to narrow the problem down? the second problem is when i start the truck and shift it into gear it stalls, i have never heard of this before is there anyone that can help me? i would really appreciate that.
RE: i have a problem can anyone help?
fuel could be alot of things. but the stalling could be a bad mass airflow sencer among other things. if your service engine soon light is on then take it to autozone or advanced to get it tested.
I have the same problem with my 2K Blazer and do the same as m00nwater, trip gauge to get gas. If that won't work for ya, then more then likely you have to replace the sending unit. It is located in the gas tank. Not a cheap endevor!!!! While your there, replace the fuel pump too.
As for the stalling, I would change the fuel filter first. If that fixes the problem then your golden, however if it doesn't then I would have the fuel pressure tested, although it could be any number of things. Sensor to tranny.
ORIGINAL: Hanr3
No kidding!!! I had to redo the tank and sending unit in my old Volvo...I know they're not cheap to beging with, but it was $200 for teh tank (at a discounted price), plus it was $500 for the sending unit!!! I ended up jimmying up a GM one and it worked fine, but still...$$$$$
travisrussell88
The Chop Shop
08-03-2010 04:25 PM
hotrod413
10-16-2009 12:20 PM
hey all, 87' blazer s10 owner here, having a problem. anyone help me? i can post in tech problems fo
blazer_geezer
04-27-2007 01:55 AM
blazer123456789
01-11-2007 11:26 PM
