Ignition switch problem ?
UPDATE
Cleaned all battery cables and ground connections.Drove it for almost a week.
Problem still there.
Bought new switch at Auto Zone for $90.00.
Problem solved....
Only problem installing was getting the 2 screws out.It didn't have the tamper proof torx screws.
Had to use a deep dish #4 metric socket and cut a paper clip the length of it and stuck in it and it fit perfect.
Problem solved....
i had the same problem with 97 blazer (it seems this might be the most common problem dang)
i replaced the ignition switch and it was like the light from heaven blinded me... my 2 year blinking check engine light turned off, still off, crazy i swear my transmission shifts better now too... it was brand new... cranked right up one turn... until morning... every morning my battery dies... still looking for reason 2 sep fuses have this connecting drain... spuds704 might have given me what i am looking for at least... faulty ground... but where ??
nothing has been done to this car at any shop recently i did notice my passenger window will not work if from passenger switch only drivers switch (even with lock off hheh) i did however just re-attach my drivers door panel and wonder if i have clipped a wire or something in that process... does any one no if the #13 radio fuse and the #1 brake fuse have any business in the drivers door ?
thanks
thanks
Yes, but you'll need the electrical schematic for your specific model year vehicle. It's a matter of checking voltage at each pin, in each position, (Acc, off, run, and crank) at the ignition switch connector.
NOTE: The ignition switch and electrical schematic used on 1997 is unique to that year. The schematic in the "Anatomy of the ignition switch" link does not apply to 1997.
