interior lights wont shut off
Old 01-11-2007, 10:25 PM
Melodyjn's Avatar
Melodyjn is an unknown quantity at this point
Default interior lights wont shut off
I have a 97 blazer, Just recently non of my interior lights will shut off when I shut the doors, car engine off or on. I have to pull the fuse out so the battery doesnt die.
Can anyone help?
Thanks
Old 01-11-2007, 10:36 PM
Default RE: interior lights wont shut off
Probably a door switch.
Old 01-12-2007, 12:10 AM
rooster's Avatar
rooster is an unknown quantity at this point
or dimmer switch, does rear stay on too. what i do is to just pull one side of the bulb out. alot easier then a fuse and kinda acts like a manuel dome switch. lol
Old 01-12-2007, 12:39 AM
Chevy Lover's Avatar
Remove the door switches one at a time. When the interior lights go out, you have found the faulty switch. You probably have one shorted to ground.
Old 01-12-2007, 04:55 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
ORIGINAL: Chevy Lover
This is correct. Check all the door jam switches even the one for the tail gate. If one of them is faulty (grounded constant) then your lights wont go off when everything is closed. The only other thing that would cause it is if its a 4 door and the rear door(s) are misaligned, if this happens then it does not contact the switch correctly.
Old 01-12-2007, 09:24 PM
RQuickDraw's Avatar
RQuickDraw is on a distinguished road
I had this same problem with my Jimmy a couple of months ago. I was one of the door jamb switches. Took a little detective work to find the right rear switch was bad.
KingKliq1
11-25-2014 11:18 AM
mjallen
11-05-2014 11:24 PM
dlmallory
02-21-2012 09:54 PM
chester92
11-14-2011 02:50 AM
burnout350
04-28-2009 01:25 AM
Quick Reply: interior lights wont shut off
