Introduction and need help please
Hi my names Kodie from auburn Washington.
I bought a 97 blazer first one ever owned that’s Starts up revs to 3000 rpm for about 3 seconds then Boggs down and dies after I’ve replaced the map sensor, maf sensor, tps sensor and about to replace the fuel filter. i was wondering if anyone else has had this problem and id they have any advice that could help thank you for your time |
Welcome,
Fuel Pump? do you have pressure from pump? Other will chime in shortly with suggestions |
Welcome to the Blazer Forum...
First, welcome to forum!
Second, go ahead and check your fuel pressure before you throw anymore money at it. There's some really good write ups on here on how to do it. Are there any trouble codes present? Cel on? |
*Moved thread to '2nd Gen tech'*
I will look at the fuel pressure and it showed no codes which I thought was weird
Originally Posted by Kodieking206
(Post 707195)
Sounds like the MAF sensor is not plugged-in; check the connector for it.
Originally Posted by LannyL81
(Post 707463)
