Just got my DMV renewal notice...
I have to turn in a smog cert with my renewal fees this year. Problem is, I might have a busted heater core which I haven't had looked at yet. Anyone know if this could make me fail my smog test? I'm trying to find out if I should get this fixed before my smog cert or if I can skate by and save a a few more duckets to get the heater core fixed after the smog test.
RE: Just got my DMV renewal notice...
i wouldnt think that the heater core would hurt you passing or not.
But im the A/V guy
But im the A/V guy
I can't see any reason for a leaking heater core to be a problem with a smog test, but then again, I don't know the requirements for Canada either...
Thanks for the advice, good news is that I'm actually in California, not Canada
Ah yes, sorry, my bad. So many times I see CA in someones profile and automatically think Canada.
Anyway, the heater core shouldn't be an issue in Cali.
Your heater core can only affect the smog test if it is leaking coolant like a broken dam, and won't allow the engine to reach closed loop mode in the programed time and sets a DTC code...
ORIGINAL: 20Blazer00
If the leak is big enough then you would definitely smell hot coolant.
The check engine light might not come on depending on how many times the drive cycle has been completed. Some DTC's never set a MIL Light...you would notice that the temp gauge would sit at the lower ranges...that is how I figured out my T-stat was stuck open...
username772
08-11-2013 11:41 PM
96jimmyslt4x4
05-29-2011 11:22 AM
PaulO2288
Headers, Intake, & Exhaust
05-10-2009 07:43 PM
ivannj
11-28-2005 09:43 PM
