Just got something new check it out
Old 01-17-2006, 04:39 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default Just got something new check it out
I think this is my final upgrade to my truck which I just got in not to long ago. The accell 300+ ingnition system. I have put on so far a Gibson exhuast, CAI, throttle body spacer, super coil, Hypertech programmer 111, electric fan, performance pulleys, B&M supercooler, B&M tranny pan, and some purple oil. Now this ignition system will top it off. I will write back later after install to let you know how it runs.
Old 01-18-2006, 08:37 PM
ivannj's Avatar
Default RE: Just got something new check it out
well I tell you that it was not much of a horse powerlike 10n but the throttle response is 30% better. But everything put together makes the ride neck snapping.
Old 01-18-2006, 09:52 PM
What coil are you running? I hope it isn't an accell. I have heard nothing but bad things about Accell ignition modules and coils once temperatures go back up in the summer. Good luck, but if you start to have trouble, I'd look at replacing the Accell items first.
Old 01-18-2006, 10:01 PM
ivannj's Avatar
Well I hope not for 270 buck I just spent on the 300+ ignition system and 52 bucks for the super coil. Why does it give problems in the summer?
Old 01-18-2006, 10:10 PM
From what I understand, the electronics over heat and melt themselves down. Not enough of a robust design and a lack of adequate cooling. The heat sinks are a joke if you don't mount them in an area that gets air flow.
Old 01-18-2006, 10:11 PM
How was the installation? How well did it integrate in with the factory controls?
Old 01-18-2006, 10:35 PM
HCCAFan is an unknown quantity at this point
Gibson actually makes an exhaust for our trucks? Where can I get it?
Old 01-18-2006, 10:39 PM
ivannj's Avatar
GO to summitracing.com and do a new search for your vehicle bam exhuast sytems and there you go. The installation was easy plug the coil plug to the accel and the accel plug to the coil and thats it.
97chevyblaze
08-02-2010 09:22 AM
jawsjr01
11-08-2008 10:56 AM
ivannj
01-13-2006 08:18 PM
ivannj
11-28-2005 09:43 PM
blazergirl15
07-09-2005 03:26 AM
Quick Reply: Just got something new check it out
