Knocking noise when hitting bumps
Old 05-09-2008, 01:46 PM
bobbyj42's Avatar
bobbyj42 is an unknown quantity at this point
Default Knocking noise when hitting bumps
I have a 2001 Blazer 2dr Rear Wheel Drive... Whenever I hit bumps, I can hear a knocking noise in the passenger side near the firewall. The ball joints on that side have been replaced. I simply cannot figure out what it is. Any thoughts?
Old 05-09-2008, 04:14 PM
WolfPack's Avatar
Default RE: Knocking noise when hitting bumps
Control arm bushing?
Old 05-11-2008, 10:43 PM
leeps is an unknown quantity at this point
I had that same problem with my '02 Blazer. I would hear the noise on small bumps and when applying the brakes, right on the passenger side like you have. Since years ago I had a similar problem and replacing the badshocks solved the problem back then,I replacedminebut the annoying knock persisted. Eventually I found out the problem was the idler arm. I replaced it and the knocking stopped, almost completely. I had warped front rotors so I replaced them too and now it no longer knocks. I hope this helps.
Old 05-13-2008, 12:45 AM
obso is an unknown quantity at this point
Check the torsion bar mount also. Had one go out on a 92 jimmy and it sounded like hell. Replaced the entire front end before someone mentioned that mount.
02Goldie_Loks
10-29-2015 10:08 PM
dbleobarbie
11-15-2013 11:39 AM
Nick Bain
02-25-2009 03:58 PM
daxsteel
11-09-2008 09:44 PM
blazergirl15
07-09-2005 03:26 AM
Quick Reply: Knocking noise when hitting bumps
