Largest size tire and tranmission question
I just picked up a 97 Blazer 4x4 It has 124k miles on it
1st ? What is the largest tire I can run without lifting or cutting?
2nd ? The trans has no forward gears (just reverse) Could this be a valve or sensor problem?
#1- check out the Tires & Wheels section
#2- What is the condition and level of the transmission fluid (check warmed up, engine running, on a flat level surface)? Did this problem occur suddenly or gradually?
Looks like 30/10.5/15 is as big as I can go..
I bought it like this today, so I have no history on it
the stock trans is the 4L60E
