Leaf Spring End Tip Pad Anti Squeak
Does the vehicle have 4 wheel drive? There is definitely a vacuum leak in the HVAC vacuum supply. Which could be causing the low lambda voltage. Possibly a faulty vacuum check valve. Is the vehicle right hand drive or left hand drive? In the image below, you can see the power brake booster and master cylinder on a left hand drive vehicle.
Your welcome for my response but the thanks goes to captain! He's far more knowledgable than I with the tech side so your in about the best hands you could hope for at this point as far as I'm concerned!
Captian yes it is a 4x4 and I am driving on the same side as you in the US.
Only UK still have Pounds as currency & driving on the wrong side.
Shall I start plugging the cuircuts ti identify the leaks cuircut?
BR
Bob
BR bob
ChevyBlazer4uHaters
01-09-2014 03:39 AM
musclemasterflex
Suspension Tech
08-26-2011 09:10 AM
