Lock Cylinder and top steering Shroud Help!
Old 05-12-2019, 01:29 PM
BorderCougah's Avatar
BorderCougah is on a distinguished road
Default Lock Cylinder and top steering Shroud Help!
Hey guys.
So. Question. How in the name of all hell do you remove the top steering shroud from a '97 Blazer?! Does it involve removing the lock cylinder as well? And if so, how does one do that?
Everything I'm finding is for 98+, which has a different style of shroud where the top and bottom mate around the lock cylinder.
But the 97 I have, has the top shroud go AROUND the lock cylinder, as seen here (Mine is slightly broken in a desperation move):
Any help I can get is appreciated.
Thanks.
Old 05-12-2019, 01:50 PM
2001ZR2's Avatar
On the right hand side there is a small external tor screw I think it's an E4
Look from the bottom and it will be plain as day
Old 05-12-2019, 02:08 PM
I saw two E4 screws, but both held the ignition switch in place so far as I can tell. Couldn't see one that held the cylinder or shroud in place.
Again, this is for a 1997. NOT a 1998+.
Old 05-12-2019, 09:16 PM
Toms's Avatar
Toms is on a distinguished road
If you are trying to remove the lock cylinder, on my 2002 you just need the bottom half off to get to the release hole to release the cylinder. Mine had the little bolts that released the top half of the shroud. Hope this helps a little.
Tuna
03-26-2022 02:32 PM
Tuna
07-20-2014 06:45 PM
pablo420
01-13-2013 06:02 PM
Hammond1524
04-23-2011 03:46 AM
nitelife
04-02-2010 10:26 PM
Quick Reply: Lock Cylinder and top steering Shroud Help!
