Looking for a Diagram for Catalytic Converter Replacement
My 2003 Chevy Blazer LS 4.3L gave me the following codes last night when I ran a test with my OBDII reader:
P0440 Evaporative Emission Control System Malfunction
P0420 Catalyst System Efficiency Below Threshold
My catalytic converter seemed to have had a rattle for awhile, so I knew it's needing to be replaced. So, I ordered one online today.
What I am looking for is a DIAGRAM of the removal and installation process.
If anyone has one, please share with me! Looking to do this fix soon.
run_girl: if you are getting the one piece cat with Y pipe, no cutting is done except to make removal easier. However to install the new piece requires removal of a cross member in order to get the one piece in place. May not have to completely remove the cross member, but needs to drop down on the the right side.
Not difficult or anything, just something that has to be done....at least that is what I had to do on my 2002 4 door, 4wd which is the same as yours.
Realistically, to replace just the cat. It would only take a half hour if everything went smoothly.... unfortunately you will almost always run into a few issues- bolts can get so rusted that they have to be cut off,(I normally replace the bolts almost every time I take something apart in my exhaust) sometimes the O² sensor breaks trying to get it out. soak bolts and o2 sensor in pb blaster for an hour or so before working on it to make it easier. I'd say a couple hours is the most it would take. It can be done with one person, but sometimes an extra set of hands is helpful.
I bought a direct fit cat on my last blazer, the bolts were so rusted, I had to take a grinder with a thin cutting wheel and cut the bolts from inside the flanges. I tried everything from PB blaster, a torch, those bolts were not coming out. Grabbed the grinder and had the old cat out and the new one in within an hour. Of course, wear safety glasses and be careful if you go this route. But it was like slicing through butter. A lot of direct fits come with new gaskets and new bolts as well. Worked great for 2 years until I some idiot hit me head on. Good luck, I hope it goes well for you.
I'm working on getting the spare bits for this project and wanted to know how many Replacement Exhaust Insulators (part #36221) I'll need. One diagram that I've seen shows that I'd need 5 - but that seems excessive. Is it just one or truly 5 - or what is the right amount??
https://www.summitracing.com/parts/w...ubmodel/xtreme
