metric or SAE
metric or SAE
Are these trucks metric or SAE? 2001+ in particular ... thanks in advance.
RE: metric or SAE
They're mixed (both)
RE: metric or SAE
What are the most commonly used standard sizes? I have a pretty complete metric set ...
I need to check the vac lines for 4WD issues today, any idea what the bolts on the battery tray are offhand?
RE: metric or SAE
Yep, mostly metric.
RE: metric or SAE
I just use metric on most things since they increase in size by only 1 millimeter for each wrench.
They work fine for most US standard applications unless you are really putting some tork on a rusty bolt in US standard...then the standard wrenches work better.
RE: metric or SAE
I feel like everything I do on the blazer, I'm always having to use the 15mm socket...which always seem to escape after the first bolt comes out[:@]
RE: metric or SAE
Yeah, this is how they line up...
US Metric
1/2" 13mm
9/16" 14mm
5/8" 16mm
11/16" 17mm
US Metric
1/2" 13mm
9/16" 14mm
5/8" 16mm
11/16" 17mm
RE: metric or SAE
thanks all
RE: metric or SAE
Using a 13mm socket on a 1/2' bolt head is a good way to round it off [&o]
