2003 #1 cylinder help!!!
Old 09-06-2010, 06:09 PM
jmoller's Avatar
jmoller is on a distinguished road
Default 2003 #1 cylinder help!!!
#1 CYLINDER WET WITH FUEL. R&R cap,rotor wires,and coil were replaced. Alot of white smoke vapor out of exhaust its like #1 cylinder is not igniting what else is there to check..throttle body??
thanks alot
Old 09-06-2010, 06:19 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
did you have a skip in the motor? could also be a injector leak.
Old 09-06-2010, 06:30 PM
jmoller's Avatar
yes and how do you check the throttle body injection?
Old 09-06-2010, 07:15 PM
if you have an 03 you dont have throttle body injection. the you can dertimine if you have a injector leak by doing a fuel pressure test. and watch how fast the pressure drops.
Old 09-06-2010, 07:20 PM
jmoller's Avatar
oh ok how hard is it to get to each injection? and what should the pressure be?
Old 09-06-2010, 07:30 PM
the fuel pressure should be around 60 PSI. and your going to have to remove the upper plenum to remove the injector, but be sure to test throughly, seeing as how theese injectors are around $80
Old 09-06-2010, 07:33 PM
jmoller's Avatar
ok thanks is there one injector per cylinder tho?
Old 09-06-2010, 07:36 PM
yes there is. hers what one looks like........http://www.napaonline.com/Search/Det...+50014+2014003
Old 09-06-2010, 07:51 PM
jmoller's Avatar
thanks i really appreciate it
Old 09-06-2010, 07:52 PM
no problem
Quick Reply: 2003 #1 cylinder help!!!
