Mod a center consel shifter can you put one in???
Old 09-04-2009, 03:42 PM
Spraying46's Avatar
Spraying46 is on a distinguished road
Default Mod a center consel shifter can you put one in???
Ok so the blazer I got has a steering shifter. I want to put a floor shifter in .. I like it better plus easyier while off roading . Can it be done and is it easy??
Old 09-04-2009, 05:23 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
It can be done but a quite a bit of fabricating/parts to make it look stock. Don't forget, not only are you installing a center shifter but you'll have to remove your column shifter.
Unless you aren't worried about having two shifters and only one functional.
Just curious, though, why do you feel this would be better for offroading?
Old 09-04-2009, 05:51 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
I seen a blaze online somwere that had an lsx conversion and they put the shifter in the cup holder. looked good though. cant you just get a column from a floor shifter truck? heck proly get the console too! sounds like a trip to the boneyard is in your future!
Old 09-05-2009, 09:33 AM
Spraying46's Avatar
I. Think it better off road cause when you get stuck it is easyier to rock the ruck back and forth
Old 10-23-2009, 07:58 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
What bout a Bravada Shifter?
Old 10-23-2009, 08:32 PM
Monkeyman's Avatar
Monkeyman is on a distinguished road
Bravadas had the floor shifter as well as alot of the Jimmys/Blazers. I think all of the Blazer Extremes had them, too. I've swapped 2 S series SUVs from column shift to floor shift. It's pretty easy, tbh. There are a couple of threads on S10forum.com that explain it pretty well. Basically, you'll need the OEM floor shifter, shifter cable and console. You'll also probably want the column cover from either an SUV with the stock floor shifter or one from a 5 speed although this is for looks only (you'll have a huge hole in the column cover if you don't get the right one).
Here are a link to get you started:
http://www.s10forum.com/forum/f200/h...-pickup-56361/
Old 12-11-2009, 09:10 PM
rbcar1's Avatar
rbcar1 is on a distinguished road
Default I'll swap you
Hey I have a 98 with the floor shifter, the entire console and all. I want to do the very opposite of you and swap mine to a column shifter to have the the extra seat. Let me know if you would be interested in swapping with me.
Old 12-12-2009, 02:24 AM
Spraying46's Avatar
Default So you want. To trade me
Were are you from. I am from Marengo IL
my email is my id name @gmail.com let me know
Old 12-12-2009, 02:31 AM
Spraying46's Avatar
Has anyone supercharged there blazer !?
matthewp
04-04-2021 09:16 PM
jasedude
11-24-2010 04:03 PM
showboat
06-19-2010 09:33 AM
bigdaddykane93
12-22-2009 12:03 PM
rbcar1
12-13-2009 10:20 AM
Quick Reply: Mod a center consel shifter can you put one in???
