MY 97 262 Vortec valve rocker arm installation
Dear Forum,
I am assembling my Vortec 262 engine together and having a disput with the valve lash adjustment.
how to adjust the rockers.
I see other prosposal with firing order procedure.
The GM porcedure says
Put the engine on TDC Cyl. 1 mark and then tighten all rocker nuts with 25Nm. Don´t turn the crankshaft !!
Ist this correct.
BR
Bob
The GM Service Manual is saying:
Ist this correct.
BR
Bob
4. Apply prelube GM P/N 12345501 or equivalent to the valve rocker arm and valve rocker arm
ball bearing surfaces.
5. Install the valve rocker arms.
6. Install the valve rocker arm *****.
Important:
Once the valve rocker arm nuts are installed and properly torqued, no additional
valve lash adjustment is required.
7. Install the valve rocker arm nuts.
8. Rotate the crankshaft balancer to position the crankshaft balancer alignment mark (1) 57–63degrees clockwise or counterclockwise from the engine front cover alignment tab (2).
9. Tighten the valve rocker arm nuts.
Tighten
Tighten valve rocker arm nuts to 25
Y (18 lb ft).
Uniquemel0dy
08-28-2013 06:40 PM
