Need to wait for fuel pump before turning key
Hey All,
Have another question as well that isnt a huge deal, but I'd still like to know...
if I hopped in my car even after just a few minutes of sitting and cranked the key, itll "half start" and immediately stall - everytime.
I need to turn the key, wait for the fuel pump to do its thing, and THEN turn the key and it starts no problem. I dont have any fuel related issues with the vehicle running - of course the fuel gauge doesnt work, but whose does lol
Any idea what the issue here is? Possibly a bad fuel filter? I really have no idea where to start.
Hey All,
Maybe that's just how it is with this truck, and you cant just start it prior to the pump running. But that is what I am wanting to know.
Right, like I said, its not a huge deal or anything but on most cars, especially push to start, you get in and crank the key immediately and it starts without waiting for anything. With this thing it's like it doesnt have the fuel there until you let the pump do its thing for a few seconds.
Mine does that, too.
What I think it is, is the fuel system isn't holding pressure like it should. So it takes a second to build up enough pressure to run the engine. I know mine will bleed down fuel pressure, even with a new pump and regulator. Doesn't seem to affect it running, so I don't worry about it.
For funsies, rent a fuel pressure tester, and see what it does
Since push button start (or direct injection) engines have a fuel line pressure of anywhere between 500-2,200 psi and an older port injection style has around 50-60 psi, you can see why the new style has a quicker type ignition. It's also why you need to know what you're doing when working on fuel systems on new vehicles.
My goal is to have this truck (minus a bit of rust weight reduction) back to the day it rolled off the line, so eventually I will have to drop the tank and replace the float/pump.
