New to forum..NEED HELP
Old 02-21-2012, 02:17 PM
DEATH-TRAP's Avatar
DEATH-TRAP is on a distinguished road
Exclamation New to forum..NEED HELP
Alright guys this is my first post...I got a 98' blazer ZR2 about a month ago..I love it but the fuel gauge reads empty at all times and the light is on..I'm not sure if its. A bad ground or what but I need troubleshooting ideas before I do somethin major..any help is greatly appreciated
Old 02-21-2012, 02:23 PM
Verno's Avatar
Verno will become famous soon enough
Welcome to the forum, most things I've heard is bad ground.
Old 02-21-2012, 02:26 PM
pettyfog's Avatar
https://www.google.com/search?q=fuel...lazerforum.com
Specifically:
https://blazerforum.com/forum/tech-a...agnosis-43922/
Skip over the GM scanner diagnosis part.
Here's the best I can find. Alldata really helps in some case but when it comes to systems schematics, GM sux
What you can do.. On top the crossmemebr over the rear diff, is a major ground point. unbolt them and clean terminals. You may want to relocate the grounding bolt to face rear so you can see it.
find the harness leading to the sender assy at rear of tank. Wiggle to see if gauge starts working.
Good chance pump had been replaced. When that happens defective OEM pump connector is as well. Supplier includes butt splices which SUCK unless you have pro level tools to install them.
Old 02-22-2012, 07:01 AM
DEATH-TRAP's Avatar
Thumbs up
Specifically:
Thanx guys..that really helps ill have a look at it today if the rain holds off.....gotta love Michigan weather
nickgriffin1
11-20-2011 12:51 PM
babeba67
03-22-2011 06:07 AM
hdelgad1
11-19-2008 07:00 AM
ZeroHour
08-13-2006 10:44 PM
Quick Reply: New to forum..NEED HELP
