no 4 wheel drive
Old 05-03-2014, 01:27 PM
bugsbunny16374's Avatar
bugsbunny16374 is on a distinguished road
Default no 4 wheel drive
Have a 1999 blazer with the 3 button 4wd. When I start the blazer, the lights on all 3 buttons light up (tccm diagnostics i presume.) Then all go out. No lights on any of the buttons. I press all 3 buttons and nothing happens. I replaced all 7 major components (in this order)
1. Vacuum switch
2. vacuum actuator
3. encoder motor
4. TCCM
5. front axle switch
6. the switch on the dash
7. transfer case
Have gone over all the vacuum lines and do not see any cracks or anything that may cause a leak. Pulled the fuses for the 4wd and the ATC for 1 1/2 hours, replaced, circulated the ignition for 5 cycles. Nothing. There's no codes. I have no idea what else to do. I am completely stumped.
Old 05-31-2014, 11:01 AM
mtnlovrs's Avatar
mtnlovrs is on a distinguished road
Wow! Me too. I guess the only thing left is to ring-out the wiring between the switches and the actuator, motor and the TCCM. Good luck and welcome to the forum from another newbie in Kansas!
Old 06-07-2014, 02:20 PM
Changed the encoder motor and TCCM twice and still does not work so I gave up on trying to fix my 4wd issue. Removed front drive shaft and is now a 2wd Blazer. Giving the engineers in Detroit the "universal sign" and a few choice 4 letter words too.
Old 06-08-2014, 08:03 PM
chucksgarage's Avatar
chucksgarage is on a distinguished road
Default fuse
Mine 4x4 an inside lights didnt work when got it. Turned out curtesy light fuse was blown. Works great now. Why 4x4 would be combined with dome light is just dumb but it is.
mirrorimij
06-08-2019 03:34 PM
Blade_24k
02-26-2014 03:03 PM
lizzj70
06-23-2010 06:57 PM
afranchetti
01-06-2010 01:24 PM
carterx
05-21-2009 08:30 PM
Quick Reply: no 4 wheel drive
