No spark on 1997 Blazer
Old Sep 15, 2012 | 08:54 PM
gtmccormick's Avatar
gtmccormick is on a distinguished road
Default No spark on 1997 Blazer
I have a 1997 blazer it turns over fine but thiers no spark we tested at the coil the old screwdriver and wire trick to see if we could see the spark jump nothing, then replaced the coil twice still nothing. There is a wire coming out from the harness (red) right beside the battery that is not hooked up to anything wondering if maybe this wire powers the pcm? Electrical is not my stong suit so any help or dirrection would be greatly appreciated.
Old Sep 15, 2012 | 08:59 PM
With the ignition in the RUN position, does the pink wire at the ignition coil show battery voltage?
Old Sep 17, 2012 | 10:25 AM
Got it fixed loose connection thanks for pointing me in the right direction. The engine started runs good but.. i'm getting a check engine code p1864 from what iv read its a solenoid attached to the transmission do anyone know how to check it or steps on how to remove replace it. Or what it even looks like so i can get a starting point
Old Sep 17, 2012 | 08:10 PM
spittybays
Guest
Posts: n/a
JavierEscalonJr
Oct 14, 2020 11:38 PM
monette999
Jun 11, 2015 01:53 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
