No spark help please
Old 10-01-2013, 04:36 PM
billyboy2287's Avatar
billyboy2287 is on a distinguished road
Default No spark help please
Buddies blazer...97 4.3 4x4 I believe its edi. Died while he was driving it tested for fuel and spark. Shot some fuel in the intake and nothing. Took the coil wire off and no spark. I tested the pink wire and got no voltage. Now behind my back he bought a crank sensor and new coil and it still didnt start pretty crazy huh lol. Anyway is there a fuse or circuit I need to check next or is it the pcm??? Thanks you guys
Old 10-01-2013, 05:04 PM
burned's Avatar
burned is on a distinguished road
If your not getting 12 volts on the pink wire with the ignition on and the meter grounded then check the ECM IGN Fuse 10
Old 10-01-2013, 06:33 PM
If thats in the fuse panel in the truck then they are all good..
Old 10-02-2013, 02:10 PM
All fuses are good still no power. I did just notice the instrument panel is not working with the ignition on or while cranking it. The only thing left it could be is the ignition switch right/?? Come on all these views and no replies.
Old 10-02-2013, 03:11 PM
spittybays
Guest
Posts: n/a
Read this, it might help.
https://blazerforum.com/forum/2nd-ge...o-start-52956/
PS, 97 ignition switch has history of crapping out.
Old 10-02-2013, 03:18 PM
Well I tapped on the ignition switch 20 times the 21st time the gauge cluster came on and I knew at the point it would start and it did !!! I will read the article you posted thank you. One last thing the voltage is maxed out I think at 16 volts is the regulator built into the computer or is it in the alt?
Old 10-02-2013, 03:22 PM
I wish you would of posted that sooner it would of been a huge help lol. Either way thank you! I did use the search function on here but did not come across it.
Old 10-02-2013, 06:58 PM
spittybays
Guest
Posts: n/a
No boo's from the search function lovers. I find the google box on the homepage to be much more helpful. I typed in "cluster dead no start" and that was the first bf article that came.
bb sorry I couldn't have done it faster but I was busy with a blown brake line....fixed
JavierEscalonJr
10-14-2020 11:38 PM
blazzer
06-04-2013 04:40 PM
abe_f
04-01-2013 11:19 PM
Yankee Team1020
23
08-03-2011 08:05 AM
rogggg1020
11-11-2008 08:05 AM
Quick Reply: No spark help please
