no voltage present at purge solenoid or vent solenoid
I'm curious why you're playing with the solenoids, what's the problem you're trying to solve? The evap system self tests won't try to run if the fuel level is above 85% or below 15% If your fuel sending unit is bad and the tank doesn't have an accurate idea of how much fuel is in the tank - it could be causing your problem? (I'm assuming check engine light and a code or two).
code po440 evap code.probable cause.defective or loose gas cap..evap canister or hose crack or not connected..purge or vent solenoid defected..vacum leak at engine..that what i was wondering keep tank always full so evap test dosnt test.
my check engine light is off.been a week now.it was comming on every 60 to 70 miles after unscrewing hot wire at fuse box under hood.a week and no light so far.i bought new vent solenoid at chevy dearler 25 bucks and no light yet.thank you blazer forum for all the help
did you have to put a new hose on it?
cmaddox421
12-29-2013 08:33 PM
dj00140
03-14-2011 09:51 PM
Tony H
01-21-2011 10:11 AM
Tony H
02-23-2010 08:09 AM
nflea7
08-27-2007 01:29 PM
