Not enough caster/camber adjustment
Old 03-08-2014, 04:46 PM
95blazerlt's Avatar
95blazerlt is on a distinguished road
Default Not enough caster/camber adjustment
Went into work today to throw the jimmy on the new alignment machine and see how close it was as i did an alignment on it about a month ago with our old 80's style corded heads machine , I noticed the caster being at 1.8 degrees on both sides and it wanted 3.0 . Half a degree of negative camber both sides. . i tryed adjusteing the caster to get it a little higher, but cant get anymore adjustment out of the factory cam washers on the bolts. So my question is, has anyone found a caster/camber kit that gives a bit more adjustment? also my torsion bolts are run in pretty far, and im wondering becuase of the control arm angle, i dont think i will be able to get it into spec. I am wondering if the rough cuontry upper arms would help with this issue ..
Old 03-08-2014, 05:40 PM
95blazerlt's Avatar
so found some larger eccentric bolt kit +/- 2.5 degrees however not sure what measurements the factory eccentrics are.. any ideas?
dharvey4651
Suspension Tech
05-03-2015 10:54 AM
basicconcepts
02-28-2011 01:22 PM
freakgt
08-25-2010 06:38 PM
Shalom
07-21-2010 11:31 PM
jsmz
Lifting Tech
12-25-2009 12:23 PM
Quick Reply: Not enough caster/camber adjustment
