o5 2wd blazer
o5 2wd blazer
2000 miles but door panels creak like crazy,,any clues why
RE: o5 2wd blazer
2000 miles on on '06, '05? Did ya open the door too far? could need a little lithium grease sprayed on the hinges.
RE: o5 2wd blazer
the door panels (plastic)
RE: o5 2wd blazer
I would take it back to the dealership and complain. You could probably check some of the fasteners to make sure that they are tight. Just look around on the door panels for some screws and try to tighten them down (not too tight though).
If you absolutely wanted to fix it yourself, some adhesive backed foam tape on the door frame, on the inside of the door panel edge, would probably fix the problem. I'm going to be going through this in my Bravada at some point. I have a few creaks that are getting worse.
jah19862003
12-31-2006 11:18 PM
nine5blazer
10-18-2005 05:19 AM
