obd I or obd II ???
Old 07-30-2009, 08:24 PM
Biohazed's Avatar
I thought it was at first for I've hooked several ODBII scanners to it and they cannot communicate, including my Mac Tools ET-50, some cheap ODBII scanner my dad has, and a Actron ODBII scanner and non can pull a code, however the my buddy's canner which is both ODBI and ODB II can pull the codes no problem.
The running rich issue, I actually have the same problem with mine, its been that way ever since I've had it and it has a erratic idle, but she runs perfect and passes emissions every time lol
Old 07-30-2009, 11:13 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Rowe your issue sounds like a bad ICM..Just wanted to add my blazer is a 95 built 06/95 and is OBDII computer is under the hood on passenger fender..some scanners wont read mine unless you manually enter in 1996 for the year lol
Old 08-01-2009, 01:06 AM
rowe's Avatar
rowe is an unknown quantity at this point
thanks reelbroke2,,tonight i just had the thing die on me
and i hadnt gone 2 blocks after it sitting for 2 and a half hours.
it wouldnt crank back up for crap,,i was pulling on plugs and wires
hoping to get lucky and when i pulled the wire off the coil and
put it back on it fired right up,not sure if it was coincedence or if i
found something there,will find out tomorrow,,it drove all the way home
just fine but then it drove to where i went without a problem too,,so
guess its gonna be one of those problems that have to just go bad before i can
find it.
Old 08-01-2009, 11:11 PM
rowe's Avatar
well after taking out the coil and inspecting it
and the plug wire,i found nothing fisicaly wrong
no burnt or rusted areas,i put it all back together
and now it wont start at all ,so guess ill be replacing
the coil,,hope that works.
Old 08-02-2009, 03:54 AM
rowe's Avatar
just in case,,where is the icm located please?
Old 08-03-2009, 05:54 PM
reelbroke2's Avatar
If its like my 95 its mounted on the coil bracket
Old 08-03-2009, 09:12 PM
cage47's Avatar
cage47 is on a distinguished road
Yep. on the coil bracket.
Old 08-06-2009, 09:20 PM
rowe's Avatar
well thought i would post my fix on this thing
so everyone knows,it was the coil going bad
replaced it and she is running like crap again,,,,,yaaaaaa
at least its running.
Old 08-06-2009, 10:49 PM
ejschultz's Avatar
ejschultz is on a distinguished road
This sounds just like my 95 Jimmy. Runs rich, idles like crap, that top end noise you were talking about. I'll have to keep an eye on this to see what the problem(s) may be.
Old 08-08-2009, 12:45 AM
rowe's Avatar
ya,,have had this for a while now,,just havent had extra$$ to
break into it and see,,,not sure if that tapping in the top
would cause a miss,,ive had other cars that had the same and didnt
run ruff like that and rich,,almost seems like a fowl out or spark miss
but i changed all plugs wires,spider and nut kit,,also fuel pump.
only thing i havent changed along both those lines is the fuel filter.
anyway ill post as i get a chance to fix,,,,lol.
thanks for all the help everyone,,,,,
rowe.
Quick Reply: obd I or obd II ???
