oil cooler lines
oil cooler lines
you know how these things are notorious for leaking, right? well i just replaced mine and it sucked! i wouldn't even try it with out a lift handy. just thought id let you all know. at least there won't be any more oil spots in my driveway.
RE: oil cooler lines
i think that lifts are the best inventions ever lol
yeah, they definatly spoil you
My oil cooler line to the engine is leaking also. I have ramps but no lift. How hard do you think it will be to do the repair using the ramps?
Any hints on replacing them.
thanks,
thanks,
Did you go with OEM replacements or something else?
Wish I had a lift in my garage.
I havent bought them yet but I am planning on OEM.
ORIGINAL: 99blazingred
thanks,
thanks,
Reason I ask. I have heard of guys replacing the OEM stuff with regular fittings. They split the metal pressed clamp fitting on the OEM hoses, peel it back and pull out the OEM fitting. Basically taking the fitting off without cutting the hose. Then slide the OEM hose over regular barb fitting and using pipe clamps to hold it in place.
i eliminated the oil cooler all together i have a 96 4wd an d i bought the nipple for the 2wd that goes where the cooler does off the block so now i just put my filter where the cooler went. i have to use a shorter filter now and its a lil harder to change but i dont have to use that damn oil cooler and all its leaky lines plus when i changed the engine they said id have to get a whole new oil cooling system because u cant flush all the contaminent out of the old one enough to ensure u wont damage the new engine with old crap
fslobodecki@yahoo.com
04-15-2011 03:29 PM
subarugt06
03-06-2011 11:21 AM
ComputerNerdBD
26
11-10-2009 12:21 PM
