Oil drain plug location
This sounds like a dumb question, but where is the engine oil drain plug for a 95 blazer? 4.3 4x4. I went to change the oil, but it is not as obvious as it would seem. I can access the filter ok, but wheres the plug?
Thanks!
Thanks!
RE: Oil drain plug location
It may be on the oil pan, underneath the engine block.
On my 96 I just bought I had to look for it a minute too.
I found mine at the rear of the oilpan facing the back of the vehicle.
i had a 95.......ls s10 4x4 , its tucked towards the back of the pan, have to really get under there to see it, as its not facing downward like most
ok, so its on the pan directly under the engine. I will crawl under there again tomarrow.
Thanks!
Thanks!
gooder
05-04-2008 04:10 PM
boulonman
03-05-2007 05:10 AM
2001Blazer4x4
03-02-2005 10:45 PM
