Oil Pressue at 3/4 for like a half an hour to an hour
Lately, when I go out and start my Blazer up, the oil pressure seems to be riding at the 3/4 mark. It normally rides at the 1/2 mark. So its a little more high pressure then I thought. Could that have something to do with the oil line still leaking? Or is that pressure characteristic normal for a cold weather climate. Its like 20F or -10C here these days. I have 5W30 going through a liter of oil every couple days. Its too cold out to do the oil line fix, or I am probably just procrastinating. I looked under my rig, its my damn engine block to filter line. How the heck am I suppose to get at the block line?
my blazer has increased oil pressure when started in the cold too almost every vehicle I have owned was the same ,nothing I would worry about as for your oil leak what I would do is cut an inch or two at the leak get 2 high pressure fuel clamps and a piece of fuel line.. The clamps will not loosen and you would be fine until the warmer weather, it will hold up for as long as you want it to
sjmcarz
23
03-18-2012 03:34 PM
ddog800
14
02-16-2011 03:01 PM
jstutzman
06-04-2009 08:23 PM
