ok I'm stumped
Old 06-03-2012, 03:24 PM
lndianScout's Avatar
lndianScout is on a distinguished road
Default ok I'm stumped
when I purchased my blazer I knew the speedo wasn't working, so I figure no problem, I've replaced the VSS on my other 2 so why should this one be so different
wrong..
first thing I did was change the VSS, still no speedo or odometer, then I removed the cluster looked for bad solder connections resoldered a few, reinstalled it, same no speedo or odemeter.
so the whole time the transmission shifts prefect, I went out and tested the cruise control it's working great, so the vss has to be working
am I looking at a bad stepping motor in the dash for the speedo??
Old 06-03-2012, 05:23 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
what year blazer? it could also be the connection at the trans case, unless thats the VSS ur talking about. if not, try there......its a boxy looking thing that has ur speedo cable attached to it thats attached to the trans case. if its broke or sticky ur speedo or odometer wont work.
youngbloodsno111
03-23-2019 07:00 AM
black99gm
10-31-2009 06:13 PM
Joey P.
12-21-2006 09:23 PM
pinkituscaderro
07-05-2006 04:28 AM
94_4.3dago
29
02-08-2006 07:21 PM
Quick Reply: ok I'm stumped
