one side of truck higher then other!
Old 02-20-2011, 09:20 PM
dj00140's Avatar
dj00140 is on a distinguished road
Default one side of truck higher then other!
Ok I measured the left tow hook on my truck and it was 5/8" lower then the other, and I could see it was slanted so If I measured at the end of the truck I am sure it would be more pronounced. I need new shocks, I just rebuilt most of the front end and got new tires.. what can cause this...
Old 02-20-2011, 11:20 PM
AJBert's Avatar
AJBert is a jewel in the roughAJBert is a jewel in the roughAJBert is a jewel in the rough
Worn out torsion bar on the the side that is lower. About 2-3 turns on the lower side should even things up.
Old 02-21-2011, 01:43 AM
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
My 2000 blazer also has this problem.. so just cranking on the torsion bolts will level it back out then.. Or would it be better just to replace the torsion bar?
Old 02-21-2011, 07:56 AM
AJBert's Avatar
I would be better to replace both at the same time IF, in fact, you have a worn out tbar. Take a look at the rears springs, too. If you have one that is cracked it can also cause the front to be uneven.
Old 02-21-2011, 02:31 PM
dj00140's Avatar
Leaf springs? Ill check those out, I gotta go in for an alignment check so...
Old 02-22-2011, 11:07 PM
dj00140's Avatar
I found the t-bar, how do I know if its worn out?
Old 02-25-2011, 10:39 PM
AJBert's Avatar
If you turn the bolt and it has little to no effect then it is worn out. Just make sure you keep track of how many turns you do. One complete turn should raise that side about 1/4". If it doesn't it is probably time to change it out.
upmaine
07-09-2012 12:31 PM
DR_KONG
Lowering Tech
03-29-2011 10:44 AM
DR_KONG
03-28-2011 08:28 PM
2KBVDA
10-30-2008 03:52 PM
MEHusky
04-27-2008 07:19 PM
Quick Reply: one side of truck higher then other!
