overhead console w/ trip and remote compass?
Old 08-29-2010, 11:53 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default overhead console w/ trip and remote compass?
I just installed an DIC with trip from a Bravada with a short overhead console. Everythings works correctly except the compass. Where exactly is the remote compass mounted on the trucks with short ohc's and trip computers? I need it for my compass to work, I believe. Thanks.
Old 08-29-2010, 03:06 PM
The compass module should be right there in the overhead console.
Old 08-29-2010, 03:12 PM
rriddle3's Avatar
If it's just a matter of the compass not reading correctly, here's how to calibrate it:
The compass is self
-calibrating, so it does not need to be
manually set. However, if C (Calibration) is displayed,
the compass will need to be calibrated. You may also
place the compass in a noncalibrated mode by pressing
and holding the MODE and US/MET buttons
simultaneously while in the COMP/TEMP mode. After
about 10 seconds, the compass will display C and you
can release the buttons. Drive the vehicle in a complete
360 degree circle three times at a speed of less than
5 mph (8 km/h), and the compass will function
normally. Once the calibration is complete, the display
will return to a compass reading.
Old 08-30-2010, 08:24 AM
I need the remote compass before I can calibrate. Thanks for the info, Kyle.
I noticed there are four versions of the DIC.
Originally Posted by syty.net
In the second gen S10's there are 4 differant displays used
Long console with trip function (has 9 pin power connector)
Long console without trip function (has 6 pin power connector)
Short console with trip function (has 9 pin power connector and 6 pin connector for remote compass sensor)
Short console without trip function (has 6 pin power connector and 6 pin connector for remote compass sensor)
In the first gens there is only display, that I've ever seen, it has the 6 pin power connector and does not have the trip function, since there is no class 2 data buss to supplu the info
This connector is only on displays from short console, it goes to the remote compass display sensor, on the mounting bracket
Connector Part Information 22-01-3067
Pin Wire Color Circuit No. Function
1 GRN -- East/West (-)
2 RED -- East/West (+)
3 CLR -- Ground
4 -- -- Not Used
5 WHT -- North/South (-)
6 BLK -- North/South (+)
This is the other end of the cable, it goes to the sensor itself
Connector Part Information XHP-6
1 BLK -- North/South (+)
2 WHT -- North/South (-)
3 -- -- Not Used
4 CLR -- Ground
5 RED -- East/West (+)
6 GRN -- East/West (-)
Console with 9 pin connector, has trip function (Trip function will not work in 2.2 trucks)
Connector Part Information 12064980
7 DK GRN 1301 RAP Fuse Supply Voltage
8 BLK/WHT 451 Ground
9 DK GRN/WHT817 Vehicle Speed Signal
10 LT GRN/BLK 735 Outside Air Temperature Sensor Signal
11 GRY 1220 Instrument Panel Lamp Fuse Supply Voltage - 2
12 PPL/WHT 1382 LED Dimming Signal
13 -- -- Not Used
14 ORN 40 Battery Positive Voltage
15 YEL 1127 Trip Computer/Nav Class 2 Serial Data
Console with 6 pin connector, does not has trip function
Connector Part Information 12064993
5 DK GRN 1301 RAP [X] Fuse Supply Voltage
6 BLK/WHT 451 Ground
7 DK GRN/WHT817 VSS Signal
8 LT GRN/BLK 735 Outside Air Temperature Sensor Signal
9 GRY 1220 Instrument Panel Lamp Fuse Supply Voltage - 2
10 PPL/WHT 1382 LED Dimming Signal
Outside air sensor (located on radiator support)
Connector Part Information 12052641
A BLK/WHT 451 Ground
B LT GRN/BLK 735 Outside Air Temperature Sensor Signal
Old 08-30-2010, 11:39 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Here is a pic of the remote compass on the units that had the short console. Why GM made 2 different kinds I have no idea. The remote unit is located on the arm of the black piece that outer shell screws into. This is one from a 97 Bravada with the short OHC. This is mounted on the topside of the arm on the piece thats mounted to the roof. I missed this item the first time and had to go back and get it.
fortheson33
04-09-2015 06:13 PM
warthogdriver
05-12-2012 01:32 PM
MikeRo
04-02-2012 11:05 PM
De_Greaser
02-25-2012 08:16 PM
Rob02150
05-05-2009 07:47 AM
Quick Reply: overhead console w/ trip and remote compass?
