Parking brake
Parking brake
1998 s-10 blazer...OK, the parking brake never made a "ratchet" sound and worked fine, then the pedal would not stay down; I sprayed lube on it and it worked again for a good long time...but now the pedal does not stay down again...what is going on here?
RE: Parking brake
check your left rear wheel. take off the wheel and make sure that the parking brake is still making contact. the pins get worn back there (i think)
RE: Parking brake
It could be that the parking brake ratchett assembly is worn and needs replacing. It could also be that the pedal is bent and no longer has the gears in the correct position to catch.
Does the park brake hold the truck if you keep your foot on the pedal?
RE: Parking brake
Funny you should mention it,the e-brake on my '02 doesn't ratchet down, either. The pedal just moves like the regular brake pedal does and then locks. It obviously works though, it holds the truck in neutral on a slope.
RE: Parking brake
Right...I do not believe there is a conventional ratchet here....does anyone else agree?
RE: Parking brake
I bought my 01 blazer a week ago with the pedal doing this. It would brake, just wouldn't stay down. I replaced the assymbly instead of trying to figure out the spring. It took about 20 minutes total to do the job.
The part is $29 on gmpartsdirect.The GMpart number is 15016010 for 98-05 I think, just verify that it says it will work on your year.
RE: Parking brake
The lever works with a rack and pinion gearset....the pinion locks when you press the lever...that is why you do not hear the normal ratchet sound.....Thanks for the info on GM parts direct!...PM
xderkax
01-14-2010 11:38 PM
blackknight
02-08-2007 03:27 AM
