Parking light stays on
Ok I have a 2001 chev blazer 4wd 4dr that the brake light stays on! Won’t go out out! Now for the things I’ve tried
reset computer
replaced pads & rotors
calipers are good
abs wheel and senors are good
fluid level at max
no leaks at any of the wheels
checkled and unplugged sensor at fluid res.
no ABS problems or lights or codes
What do I need to do next?
reset computer
calipers are good
fluid level at max
I'm a little confused...
You post title says "parking light", then in your post you say "brake light". Then you go as far as mentioning resetting the computer and checking the brake fluid level, which leads me to believe you're referring to the "BRAKE" light in the cluster?
From what I gather with your information it sounds like a faulty brakelight switch. Usually cheap and easy to replace. However I agree with the question/post being confusing... so my answer may or may not be correct.
Amber Kay
12-22-2015 08:46 AM
Diablo1982
08-18-2011 11:08 AM
