Passenger window controls
I had some speakers installed in my 2001 Blazer LT 4 Door, and now the window controls on all of the passenger doors don't work the windows. I removed the panels and checked all connections but everything looks OK. The widow lock is not on and I can control everything fine from the drivers door but not passengers. However when operating from the drivers side and pressing a passenger control it stops the window operation. What could be causing this? Whats next? Also, I can work the locks just fine.
If you push a button on the drivers controls and it stops a passenger window that's normal (passenger switches work only if drivers are at rest position) If they all worked before then recheck the 4 pin connector 2nd from the front on drivers side - passenger window lockout switch. If it's snapped in correctly look closely at your connectors to see if a wire walked back out of the connector. If all the wires look to be good pull the 4 wire connector out of the drivers lockout control and jump the dark blue to the dark green with a piece of wire, this is like turning the lock off. If that works the lockout switch is bad.
aaronjohn20
03-20-2008 12:51 PM
bowanna03
01-08-2007 11:23 AM
hillbillyinOhio
07-12-2006 04:18 AM
