Quick help needed! Secuirty breach!
Old 12-12-2007, 06:57 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default Quick help needed! Secuirty breach!
My blazer will not start at all, I read the code and it says that secuirty wont let fuel pump activate..
Anyone know how to disable this?
Disconnect the battery?
Edit heres the code
P1260 Theft Detected - Engine Disabled. but it said fuel pump disabled
Old 12-12-2007, 07:20 PM
Default RE: Quick help needed! Secuirty breach!
Are you sure it was P1260???
P1260 - Fuel Pump Speed Relay Control Circuit
But then again, I found this through OBDII.com (GM specific), but I do not think this is a code that applies to the S-series as there is no fuel pump speed relay in the s-series trucks.
Coupled with your other problem, Just died...., this may be the beginning of an ignition switch failure.
Old 12-12-2007, 07:26 PM
Zasder's Avatar
it had a 1 and a 6 in it.....
The message deff said Security threat fuel pump disabled...
should I just have it towed to my dealer tomorrow mourning and have him take a good look over?
Old 12-12-2007, 09:21 PM
hillbillyinOhio's Avatar
what year blazer???
Old 12-12-2007, 09:49 PM
Hanr3's Avatar
My '00 had security issues. Fortunately it was under warrenty, and the dealer replaced the ignition switch. It would start sometimes, and not others, when it didn't start the security light would come on.
Old 12-12-2007, 11:04 PM
WolfPack's Avatar
thats what mine does!!! wow I could never find anyone that had the same issue..woo doggy. anyhow, would you classify the ignition switch as a DIY possibility or should I just pay for that one?
Old 12-12-2007, 11:11 PM
looks that way. just found this link on our forum.
Ignition Switch R&R
Old 12-13-2007, 01:08 AM
Chevy Lover's Avatar
ORIGINAL: hillbillyinOhio
what year blazer???
It's a lot easier to help when we know what we're looking at.
Old 12-13-2007, 07:54 PM
Zasder's Avatar
My bad, its in my sig now....
I still have warrenty on mine so Ill just throw at my dealer....
brooklynRick
07-08-2011 05:14 PM
sleepterror
11-28-2008 06:30 PM
blazinwoody
Engine & Internal
01-11-2007 05:30 PM
strongboy2005
02-03-2006 10:07 PM
Quick Reply: Quick help needed! Secuirty breach!
