rag joint change
Old 10-21-2012, 08:07 AM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Originally Posted by coolasice
i'd rather live with it crooked and have it straightned next time i need a alignment
If the steering wheel is off too much they wont be able to straighten it up
Old 10-21-2012, 08:59 AM
newguy's Avatar
Wasnt there splines on the shaft were the rag joint goes? maybe thats off
Old 10-21-2012, 04:06 PM
coolasice's Avatar
coolasice will become famous soon enough
i made sure the joint was on correctly, and it's not off enough to not fix via alignment. my guess is the p.o. had an alignment done with the joint slop and the steering was actually crooked when the aligned it...
Old 10-21-2012, 05:45 PM
97cherryblazer's Avatar
97cherryblazer will become famous soon enough97cherryblazer will become famous soon enough
Mine is the same way after replacing the joint.
Old 10-21-2012, 07:11 PM
coolasice's Avatar
I'm glad i'm not the only one! Also just replaced the transfercase vacuum switch.... what a B! My huge hands almost couldn't reach it... Replaced a bunch of vacuum hoses also.
Old 10-21-2012, 07:15 PM
4x4blazerguy's Avatar
Have you taken it to an alignment shop? Bad alignment will cause the wheel to be off center. If you replaced front end parts & didn't get it realigned then that is most likely your problem.
Old 10-21-2012, 07:21 PM
I had mine aligned right before i did my rag joint. and it still tracks straight as can be. im not really worried about it.
Old 10-21-2012, 08:20 PM
coolasice's Avatar
rag joint has zero effect on the alignment...
Old 10-21-2012, 09:16 PM
mr.vls's Avatar
mr.vls will become famous soon enough
Centering of the steering wheel can be accomplished via adjusting the Tie Rod Ends which is done as part of the vehical alignment.
Old 10-21-2012, 09:36 PM
coolasice's Avatar
and as stated earlier, my alignment is good prior to the rag joint replacement... I will not pay $70 just to get my steering wheel straight
Quick Reply: rag joint change
