Rattle/vibration in drive with break applied
When I hold the blazer at a stand-still in any gear (R, OD, D, 2, 1) with the break applied I can hear a rattling vibration noise from under the car. It sound like it comes from under the passenger seat area but under the car. It's not there when I put it in park. And goes away when I start driving. Any suggestions on what this is? Something loose maybe?
You can go ahead and ignore it for about two years, but the chunks will eventually plug it and then you'll really be in trouble.
When it really gets bad, all sorts of weird stuff will happen, first you'll notice that the shift points go WAY up and there is no power to ever get to them, then when it's totally plugged, there will be a hiss and a banging rattle at WOT and you'll be able to go about 40 up a hill if you floor it, but see no symptoms below 3K. Won't throw a CEL either!
It's real fun to have that when the only merge ramp in town is a short one!
Hope this helps!
Regards,
Thomas
jmac219
10-06-2021 09:49 AM
Suspension Plus
12-17-2008 01:54 PM
BradsBlazer
09-03-2007 09:52 PM
