rear brake swap ?
rear brake swap ?
can or will rear disc brake set upfrom a 99 blazer bolt on a 93 blazer rear end
RE: rear brake swap ?
It might but measure backing plate mounting bolt area to make sure it is the same. Or you could do the easier way just swap rear ends and master cylinder from the 99...
i am driving the 99 cant find a rear end so i am trying to make something work
Why dont you use the the drum system thats already on the 93 rear end? It should work just fine. Granted its not the same as having discs but if its gotta work that should get ya good. Might have to adapt a line or two but you should be golden otherwise.
step66
01-12-2013 10:51 AM
bill737
06-24-2011 04:24 PM
hcii
11-03-2010 08:30 AM
reagor
04-04-2010 02:48 PM
