Rear Parking brake w/ rear disc's?
I have searched all over this forum, and can't find the answer I need. I have a 1999 S-10 2-door 4WD Blazer with a 5-speed manual. When I first purchased it used, the parking brake was not working as I thought it should. It would hold the vehicle to some degree (level ground or slight grade), but not on a very steep grade at all. I adjusted everything according to the book, but still no REAL STRONG park brake. In my occupation I use my Blazer a lot, and a lot of times during the winter I have to run the heater while sitting still, and holding the regular brake gets tiresome real quick.
My question is this - I have everything to completely re-do the rear parking brake. I have both the left and right cables, the equalizer to connect the cables, and new shoes (even though the old ones looked good). At the bottom of the shoe is the park brake adjuster. On each side is a "notch" that the end of the "horseshoe" fits into. The shoe will fit in either way - meaning that the shoe will fit in with the notch in the vertical position, or with the notch in the horizontal position. Which way should it be? The notch I am speaking of is the groove that is cut out of the round adjuster. Any help is appreciated..... HCII |
http://alldatapro.com/images/smOnlineLogo.gifHome | Account | Contact ALLDATA | Log Out | HelpKERRY CHEVROLET
KERRY CHEVROLET00002 Select Vehicle | New TSBs | Technician's ReferenceComponent Search: http://alldatapro.com/images/blnk_spc.gifhttp://alldatapro.com/images/g_angle.gifhttp://alldatapro.com/images/blnk_spc.gifConversion Calculator http://alldatapro.com/images/blnk_spc.gif1999 Chevy Truck S10/T10 Blazer 4WD V6-4.3L VIN W Vehicle Level http://alldatapro.com/images/a_003366.gif Brakes and Traction Control http://alldatapro.com/images/a_003366.gif Parking Brake System http://alldatapro.com/images/a_003366.gif Parking Brake Shoe http://alldatapro.com/images/a_003366.gif Service and Repair http://alldatapro.com/images/arrow1.gif Park Brake Shoe Replacement http://alldatapro.com/images/arrow2.gifhttp://alldatapro.com/images/blnk_spc.gifPark Brake Shoe Replacement Removal Procedure
http://alldatapro.com/alldata/PRO~V1...17378/81017380
http://alldatapro.com/images/blnk_spc.gif© 2010 ALLDATA LLC. All rights reserved.Terms of Use |
