Recent fuel leak discovery...
Okay, so my '01 2wd Jimmy just recently started leaking fuel, slowly and only when running.
Only problem is, I cant tell where its coming from because nothing actually drips. I've pin-pointed the area.. but thats about it. It's where the fuel filter sits on the inside of the left frame rail and there are three lines that have connecters (from metal to plastic/hard rubber) are located.
When I first looked under and smelled fuel, the bottom of the frame in that spot was moist and the underside of my body was wet. All the lines are wet, and thats what makes it hard to tell... I sat there and watched as it ran (after cleaning the lines), and no drips... I attached a pic. My guess is that top hose, where it clamps in is the culprit... but still unsure... Want to get it fixed asap, because messing with fuel isnt fun or safe obviously. Anybody have similar problems? or anyone know some helpful tips?
In this pic, the fuel filter is on the left and the lines on right run up towards motor...
fuel line repair
look inside of the fuel line. there should be an o-ring in the line just below the collar. if the o-ring is rotten or cracked fuel wil seep out. the line says non repairable(even though there are kits out there to repair them. if its just the o-ring it can be replaced. a dental pick will get it out easily.
Thanks for that info guys! It was the o-ring after all. Put tape around the hose I suspected and let it ride for a day. After checking it, the tape was wet and fuel seeped out. Unplugged it and took the o-ring out and it was broken. Got a new one in and its all dry so far!
I have 1998 blazer LT 4x4 have fuel leak on the fuels plastic nipple the one closest to drivers side the nipple is broke right at the front of the round collar on the nipple can I use a high pressure hose and clamps to repair this. or do anybody have a way to repair this with out haven to replace pump please help
I had similar problems with my fuel lines. The Plastic parts dry and crack and start leaking. Mine were so bad that when we pulled the lines the plastic ends broke off. I ended up changing everything from the block back to the tank. The lines were gunked up as well. So check the lines real good when looking.
jewag87
07-20-2014 05:05 PM
LilMsChevy
01-11-2010 09:45 PM
