Replace water pump as preventative maintenance?
And the "I'm already dirty" factor. Come on Sister. Change the pump. The coolant drain pan is already under it. I'm fussy but I play in the snow and don't want to get stuck with the old emergency bag of walnuts in the console. They're not for eating, they're for catching something to eat.
Local auto parts stores have re manufactured pumps for $35 and new ones for $50 with a lifetime warranty. I'm going new when I replace mine.
The factory gallons per minute is more than enough for the v-6. Most of them are the same pumps for a v-8. I look more towards radiator upgrades for increased cooling.
I hadn't heard of any horror stories with water pumps and I had wondered if the ones on our 4.3l were the same as on the v8s. It's good to have that confirmed.
Heavy Duty Water Pump
So I found a water pump that is for severe duty if not higher flow rates. It is the Cardone 55-11311H. This is the description of the differences between the two models of the new pumps Cardone sells from the email I received from them:
"The 55-11311H has a ball/roller style bearing which is more durable, the 55-11311 has ball/ball bearings which is an OE design."
FYI, the part numbers for the remanufactured units are 58-521H and 58-521, the "H" referring to severe duty. I would assume the severe duty/service rebuilt one has the same upgraded bearings as the new one.
chipjumper
15
12-14-2019 08:49 AM
masterchf117
06-10-2015 08:36 AM
joejiz
18
01-23-2013 04:57 PM
ComputerNerdBD
02-09-2010 05:05 PM
