replacing vacuum switch on transfer case
Old 06-07-2007, 09:24 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: replacing vacuum switch on transfer case
OK, I guess I should have asked this in my first reply, but you seemed to have already diagnosed it. Anyway, what exactly is the concern? What type of system do you have Manual shift of electronic shift? I'll assume you have electronic, if so, what happens when you push the 4hi button? does the 4 hi indicator flash and switch back to 2hi? And does the 4Lo work?
Old 06-08-2007, 02:04 AM
fred96's Avatar
fred96 is an unknown quantity at this point
ORIGINAL: lastcoupe
i have the electronic and when i press 4hi it flashes and then 4hi stays lit, the same happens for 4lo. the lights all work properly as if there were no problem at all.
Old 06-08-2007, 11:23 AM
lastcoupe's Avatar
OK good you're on the right track then with the vacuum problem. Here's what you need to do,
FIRST...check and make sure the vacuum supply line to the t-case is CONNECTED to a vacuum source. You have a 1996, so your vacuum resevior is actually mounted to the hood itself on the driver's side, make sure the vacuum hose is connected to the tank, and check for vacuum at the t-case switch with the engine running. It should have good manifold vacuum, if not then it is either disconnected or rotted.
Next, if you have good supply here check to see if it is pressent at the actuator (under battery tray) with the engine running and t-case ineither 4wd range. Based on a previous post, I'll assume you don't have vacuum at this point, if so, you have either missrouted the vacuum hoses at the switch, or you have a rotted vacuum hose. Come to think of it, with a 96 and a vacuum problem, you should look at the passenger's side of the transmission bell-housing for the lines rubbing against something, I have repaired several of these in that location, you'll probably find a rotted vacuum line in that location.....check there after you verify the vacuum tank is connected.
cjb2145
18
10-06-2018 04:46 PM
GTTK
11-30-2014 06:07 PM
scphill34
04-05-2013 09:52 PM
jnail
01-06-2013 09:14 PM
slowhand
01-05-2010 05:14 AM
Quick Reply: replacing vacuum switch on transfer case
