"Rough Idle"
Try running some seafoam thru the fuel and vacuum systems and see if that'll help at all. Stuff works wonders. And only costs about 8 bucks a can at commie-mart. Also, your fuel trim readings sounds a little like you might have some faulty o2 sensors. Perhaps further testing there.
Thanks,
George
I have finally put together the capability to read cmp retard (CMP) using the BAFX bluetooth dongle from Amazon and Car Gauge Pro on a used Android tablet off of eBay. Some questions:
Which CMP do I use, there is a CMP* and CMP** with vastly different readings. Both are out of spec (-10, -28) so it looks like I have a distributor problem. I also have some random misfires shown on this set up which do not set any codes to discover from a standard code reader.
Can I force an idle RPM with this software and if so, how?
Once I get this straightened out I will get the fuel pressure readings that you asked for.
Thanks,
George
Les
Thanks,
George
Thanks,
George
No way to control idle speed. That requires bidirectional control.
good luck and best wishes for a successful repair.
Thanks,
George
Least expensive one I know of is one of the softwares that I have.
HP Tuners VCM Scanner. Cost about $350. Don't know if it will let you to choose an idle speed but it does do the injector balance test where fuel is cut out once cylinder at a time and it displays the rpm drop from each cylinder.
My CMP retard started off at -10.1. After loosening the distributor hold down bolt there was very little movement. I moved the distributor as far as it would go CCW and the best CMP retard I got was -8.5. Searching yields various suggestions:
Install V8 hold down
Enlarge the hold down hole
Replace the drive gear
Replace the whole distributor
What do you suggest?
Thanks,
George
Thanks,
George
After a series of life detours I am back at this. Rough idle is the issue. Today I got all of the fuel system measurements:
Pump on at the fuel rail - 62 psi
Pump off at the fuel rail - 56 psi
10 min later at the fuel rail - 55 psi
Pump on at the filter outlet = 83 psi
Pump off at the filter outlet - 82 psi
10 min later at the filter outlet - 63 psi
Lesmyer - Are you satisfied with these fuel pressure numbers?
The last time I worked on this I was only able to improve cam retard to -8.5. Today I was ready with my new distr gear, Mr. Gasket V8 hold down bolt and BAFX/Car Gauge Pro/Android set up but when I spooled up the diagnostics Car Gauge Pro won't communicate with the blue tooth dongle. Torque still works (but doesn't have cam retard) and the tablet says that its connected but Car Gauge Pro gives me an error message - "unable to connect. java.io.IOException: read failed, socket might closed or timeout, read ret:-1". I never had this problem when I originally used this set up. The internet has complaints about it but no solutions. I tried most of the usual reboots, disconnect/reconnect steps. Has anyone seen this and found a solution?
Thanks,
George
Thanks,
George
Thanks,
George
Thanks,
George
The device has to use two connections. First the tablet has to connect with the OBD2 device through bluetooth, and then the software has to initiate communication with the PCM in the Blazer. Sounds like the second part is failing.
In my experience, usually when Car Gauge Pro won't connect it is because something else is still connected using Bluetooth. Quite often I find that I have mistakenly not shut down Torque Pro and it is running in the background. Also I have found that the presence of other Bluetooth pairings like my phone to car audio and my phone to home theater sometimes seem to interfere. You may want to delete all Bluetooth pairings, and then redo the one for the OBD2 back in and try it.
I have had a couple of times where I had to pull the OBD2 adapter out and then put in back in to get a connection - but only with my new phone.
If Car Gauge Pro just won't work for you on your tablet, you can always go to Dash Command but it is a bit more expensive. You could also borrow someone else's phone and install Car Gauge Pro as a test. Just sign on to Google using your account, and then Google Play Store should let you download another copy for free.
